Reverse HDD on Lian-Li PC70
I have a Lian-Li PC70 .. and wanted to reverse my hdd so you dont have to see the connectors to clean it up.. Ihave 3 HDDs in my Floppy bay .. I took out the HDD cage that came with the case so I could put my pump there. I was thinking of running the EIDE and SATA cables through the 80mm fan in the front and up to the Floppy area.. Is this possible ? Any other ideas?
if it's anything like the PC60 you will have to permantly remove the fan or stop it and then permantly remove the dustguard and the fain grill.
Not worth it IMHOP
However it should be pretty easy just feeding the cables inbetween the drives.
