reverse hard drives antec 900
littlejohn1959
greetings ,
here my 900 with the hard drive reversed
taught id share this mod .
should help with airflow .
cheers .
I remember seeing pics of this rig :) Someone said the bottom cover looked like it was made of cardboard and you told us it was carved wood.
The HDD's look very nice, i might try that. Did you cut holes in the mobo tray to route the cables behind the case or did you just stuff the cables into the wooden cover?
the 2 sata cables are behind the mobo tray . the power cables,for the drives , are inside the wooden cover .
hope that helps .
cheers
