I just bought a v7 24" D24W33 which got pretty good reviews and I got it for a pretty good price for a 24". I was upgrading from a 15" Sony SDM-M51 analog flat panel that was many years old. I wonder what the screen technology of that thing was.
I am not a gamer, The swivel stand, frame, speakers were all good. I thought it was a nice looking monitor. The colors were just not rich enough and there seemed to be a little screen flickering when my computer processor was running. Im not sure if this was the fault of my laptop or the monitor. I was using the vga connection, not the hdmi.
The 24" is a little big for my needs unless it was going to double as a tv.
This was my plan - with a single HD cable box from Time Warner (SA 8300HDC).
A. Connect it to my living room tv using the coaxial cable and/or component.
B. Connect the hdmi out to the hdmi port of my new lcd monitor.
C Connect my pc to the vga port of the monitor.
So the one cable box controls the output on both my crt television and my lcd monitor. Only downside is you cant watch 2 different show at the same time but thats not an issue for me. So I get everything working on the lcd, even the hdmi sound.
When my 24" v7 (HDCP compliant) is set to HDMI and displaying cable signal then my non _HD analog tv will also display the same tv signal which is what I want, but when my computer monitor changes input source to vga, my analog tv no longer works and I getan HDCP error on my analog tv. In other words, given the software of the cable box, I can't output to two output devices (monitor/tv) if one of them is hdmi. I cant complain about this to Time Warner because cable boxes are intended to only go to one tv/monitor.
I could buy a more expensive LCD with component/composite inputs and that would solve my problem, Or I might just buy a cheaper 22" LCD, and then a 26" LCD/TV, thus giving up on the idea of my monitor doubling as a tv.
Are there any good recommendations for a 22"? Any non-tn that are reasonably priced?
Also what technology do most of the 26" 720p tvs use?
I thank anyone who has taken the time to read this very long winded post
