Retrofit a X99 supremacy block on 1700?
xDiVolatilX
I have a very nice supremacy x99 block that I wanna try to retrofit onto a 1700 12700kf that I have laying around.
What do I need? Just a 1700 backplate to mod?
Has anyone done this? Anything else I would need ?
If the holes don't line up on the backplate I might be able to mod the backplate right? Assuming it has enough surface area?
It's just not worth me buying another waterblock (don't suggest me to buy a 1700 block) this is for fun plus I have spare parts I wanna play with.
Any suggestions?
hititnquitit
First check to see if you can mod the top bracket to line up with socket 1700 mounting holes. If yes, then a solid backplate should be easy to source from pretty much any block or heatsink that came with one. Then you just need the hardware.
pendragon1
Extremely [H]
or modding the holes on the block might be enough, the difference is 2mm, if z height is the same...
