mustang_steve
c[H]ewbacca
- Jul 28, 2003
Kester "44" rosin core is your friend.
The thin pencil irons are avialible at most industrial electronic supply stores (RS is NOT an industrial electronic supply store).
Weller makes a few solder pencils you can find for cheap, can't remember exactly but I think it was around $30.
What you most likely saw at Cisco was a solder station. Some of those get outright scary in cost. A decent station starts at $100. A really good station starts at about $800, but many of those are overkill for the hobbyist. Just grab whatever is cost effective for how often you use it. I prefer stations myself, but don't use them often at all, so I bought a PoS $40 Elenco station. It's ghetto to the max, but it's good for soldering as fine as 26ga and as heavy as 14ga, and has the wattage to get the job done.
If you get just an iron, get a proper spring-type holder for it, it's far safer than that metal thing that comes with many irons.
