I've never built an HPTC, so I'm laying it out here on what I've figured to build for my system.
Case w/ remote deal:
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.320251.11-144-231
CPU:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103681
HD:
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136284
Mobo:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130233
Memory:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820134793
Total: 343.95 or thereabouts.
Now I'm open to criticism over what I picked out for my build, kill me if you have to. If what I've proposed is a bit overkill, I can modify my selection. I've been using the X-Box 360, but it's so damn slow streaming 720p movies off my machine in my room. So I'd like a dedicated HPTC in order to play any of those things. I'll be using Windows 7 Home 32-bit for the OS. I normally use XBMC or TheKMPlayer on my main machine since I use subtitles. But as for MPC-HC, I don't really use it because it's limited in the sense of "syncing" subs and what not.
Thanks.
CPU:
HD:
Mobo:
Memory:
Thanks.
