Unfortunately, due to the garbage that is Nero, I wrote a backup DVD and have since come to discover that it's essentially unusable. There are no physical scratches on the medium, nor are there any other marks that would inhibit perfect reading. However, the disc is basically unreadable, and I fully blame Nero for it (and myself for not checking it).
I'd like to try to salvage some of the files however, of which, some are quite large 300MB+. I've attempted to bypass Windows' insistence on giving up on transfers with a CRC error by copying via the command prompt, but the end result is the same. It will copy files partially, which, for videos, would be acceptable, but throws a CRC flag and immediately deletes the file. I've also tried to use Nero to create a single image of the drive, but it inevitably slows to an absolute crawl (<0.1x) at the offending "area".
So...my question. Is there any way to transfer single files for as long as possible and bypass the Windows CRC errors? I can't save the entire disc, but I think I can manage to save some of the larger files one at a time - I just have no idea how. Or can I construct partial or segmented ISOs?
Sub-question, is there any possible way to "rebuild" the disc? Are CRC errors due to the files themselves or, more typically, the volume/disc header being damaged? It's not a DVD-R/W, just a DVD-R, so I'm sure that'll inhibit what I can do with it.
For clarification, I'm using a Lite On DVD-R/W with RiData discs. This disc marks the first coaster I've ever experienced with a LiteOn drive.
