Recently, one of the drives in an 8-drive software RAID5 array began making a buzzing noise, but the system wasn't throwing any errors so I couldn't figure out exactly which one it was by checking logs. Thus, I thought it might be a reasonable idea to unmount the array, and unplug the drives one by one, because hey, the SATA spec allows for hotswapping, right? I found which drive it was because I could hear it spinning down. So natually, I'm going to replace it, but I decided I'd fire up the array again and back up my most recently added data, which is most important out of all the data.
Interestingly, the drive no longer buzzes. I was happy to see this, but unhappy to see that my array no longer appears anywhere on my system. I had it set up with LVM on top of mdadm RAID5. I had unplugged five devices before identifying the one that was making the noise, and that's the precise number of devices that can't be added to the array, according to dmesg:
/proc/mdstat shows no arrays, and I can't manually remove and re-add the devices to the array to get it back online, as it says that it can't get array info, and thus can't complete these operations.
So, am I hosed?
Code:
raid5: automatically using best checksumming function: generic_sse
generic_sse: 5878.000 MB/sec
raid5: using function: generic_sse (5878.000 MB/sec)
device-mapper: ioctl: 4.11.0-ioctl (2006-10-12) initialised:
dm-devel@redhat.com
TCP cubic registered
NET: Registered protocol family 1
NET: Registered protocol family 17
md: Autodetecting RAID arrays.
md: autorun ...
md: considering sdi1 ...
md: adding sdi1 ...
md: adding sdh1 ...
md: adding sdg1 ...
md: adding sdf1 ...
md: adding sde1 ...
md: adding sdd1 ...
md: adding sdc1 ...
md: adding sdb1 ...
md: created md1
md: bind<sdb1>
md: bind<sdc1>
md: bind<sdd1>
md: bind<sde1>
md: bind<sdf1>
md: bind<sdg1>
md: bind<sdh1>
md: bind<sdi1>
md: running: <sdi1><sdh1><sdg1><sdf1><sde1><sdd1><sdc1><sdb1>
md: kicking non-fresh sdg1 from array!
md: unbind<sdg1>
md: export_rdev(sdg1)
md: kicking non-fresh sde1 from array!
md: unbind<sde1>
md: export_rdev(sde1)
md: kicking non-fresh sdd1 from array!
md: unbind<sdd1>
md: export_rdev(sdd1)
md: kicking non-fresh sdc1 from array!
md: unbind<sdc1>
md: export_rdev(sdc1)
md: kicking non-fresh sdb1 from array!
md: unbind<sdb1>
md: export_rdev(sdb1)
raid5: device sdi1 operational as raid disk 7
raid5: device sdh1 operational as raid disk 6
raid5: device sdf1 operational as raid disk 4
raid5: not enough operational devices for md1 (5/8 failed)
RAID5 conf printout:
--- rd:8 wd:3
disk 4, o:1, dev:sdf1
disk 6, o:1, dev:sdh1
disk 7, o:1, dev:sdi1
raid5: failed to run raid set md1
md: pers->run() failed ...
md: do_md_run() returned -5
md: md1 stopped.
md: unbind<sdi1>
md: export_rdev(sdi1)
md: unbind<sdh1>
md: export_rdev(sdh1)
md: unbind<sdf1>
md: export_rdev(sdf1)
md: ... autorun DONE.
So, am I hosed?
