Restart VM @ specific times
capreppy
[H]ard|DCer of the Month - April 2009
Is there a way to restart a VM (via VMWare Player 3.0) at specific times in the day?
I have a VM that when it completes a WU, it will send, but won't pick up a new WU. It just waits and waits and ...
I can restart the VM and it will pick up a new WU just fine and then chug along.
I would like to automate the restart (since sometimes it completes a WU in the middle of the night and then produces nothing til I get to it), but don't know of any easy to do it. Suggestions?
:D
Forgot to mention, this isn't a notfred's VM. This is a regular VM with Ubuntu 8.04
TASKKILL /F /IM "vmware-vmx.exe"
If you put that in a batch script, and then schedule a task to run it, then the script will kill the vmware-vmx.exe process. If you schedule another task to then restart the VM, it'll get what you want. However, it's obviously a bit clumsy, but it works.
I will give this a try. I've been searching high and low and have not found anything :(
