Well, I've gotten my new computer parts and put them all in their respective places, but when I power up, all the fans will spin for a second and then it will all turn off. I've reseated everything, and don't know what to do.
Oh now that I think aobut it I did have a similiar issue once, it was because I didn't have my HS/fan seated properly and I was getting thermal shutdown.
take everything apart.
with the mobo outside of the case, attach the psu, cpu + heatsink, ram and video card.
tell us if it boots now. (you might need to lift the boot switch from your case for a bit here)
Quick poweroff like that is almost always from a short. U can leave everything in the case if u want (assuming u put the standoffs, etc. and u KNOW u did that right) and disconnect everything even hds, floppy, etc. and run just with bare essentials and if it works attach one piece at a time back while off and then power on to test, etc. If nothing then go the next step and take it out of case as suggested.
I have had this problem also and seems the lil 4Pin power supply connecter was not pluged up to the mobo. Check and make sure that it is pluged in , for a while i thought these were only nessacery when using a p4 mobo.
