What makes you think so? 16:9 is better no matter what gaming. All today's games which support widescreen support 16:9 too, at least all I play. And it gives a nice advantage online too.16:10 is best for pc gaming
1920x1200 has 11% more pixels than 1920x1080, but my impression is that 1920x1200 monitors tend to be quite a bit more expensive than 1920x1080 monitors. Most video cards and output signals in either resolution, so both are fine for computer use. However, IIRC some HD video players and game consoles output only 1920x1080 signals (not 1920x1200), so if your monitor does not support 1:1 pixel mapping, the image will stretch vertically.
Ok, I understand your analogy and I believe there has been quite a lot of discussion about 16:9vs16:10. But for gaming only (PC) I'd still get a 16:9 monitor because it looks nicer and has wider fov, which is I consider the most important in games.PC games can utilize the extra resolution of 1920x1200, where as consoles are limited to the lower rez. Cutscenes will revert to 16:9 and black bars however. Not a huge difference but IMO the more vertical viewing real estate the better.
Even run-of-the-mill crappy TN 1920x1200 monitors are still quite a bit more expensive than run-of-the-mill crappy TN 1920x1200 monitors. Here are the prices of five lowest-priced 1920x1200 monitors on NewEgg:That's if you compare the quality WUXGA monitors against the basic, run-of-the-mill crappy TN panels that are usually in those 24" 1080p resolution monitors.
yeah but if newer games and movies are priority then 16:9 can be better. some 16:9 content will just stretch on a 16:10 monitor instead of putting the black bars in. sometimes flat panel scaling through the video card drivers just doesnt work on some monitors. if the monitor itself allows it then yes you should be able display in res properly on a 16:10 monitor. problem is most monitors dont have that function.For PC use get 16:10 monitor, because on such you can always (excluding some crappy monitors) display 16:9 content. Vice versa is not possible.
