master noran
- Dec 10, 2006
Hey guy's I recently picked up a slightly damaged dell 2407, the dvi does not work and I have to use the VGA, my video card does not have a VGA connection so I use the VGA adapter the seller included, except it seems to be the only one that works. My question is that the monitor seems to only be able to display 1600x1200 and lower, is the monitor even more broken then was revealed? or is this something to do with how VGA works? Also is there any way to force it to 1920x1200?
