I have the eVGA 256 mb 6800 GT on order which is about to enhance my gaming experience (I hope) allowing me to play at higher resolutions. However there is something I am a little unsure of:
If my normal windows screen resolution is set at 1024 x 768 (which I find to be the most useable resolution for word processing and web surfing) can I independently set a game's screen resolution to a higher setting - such as 1280 x 1024 and see any difference?
Basically - do they have to be the same? - will I have to reset my screen resolution prior to starting a game and then reset it when I am done?
Thanks!
AMD Athlon 64 3000+
MSI K8N Neo Platinum
1 Gb PC 3200
128mb GeForce4 ti 4800 SE (for now...)
Thanks!
AMD Athlon 64 3000+
1 Gb PC 3200
