Resolution problem
Hi everyone,
I just bought a "eVGA e-GeForce FX 5500 256MB AGP Graphics Card" with 1 vga, 1 DVI and 1 s-video out.
The card resolution should be
Resolution & Refresh
240 Hz Max Refresh Rate
2048 x 1536 x 32bit x 60 Hz Max Analog
1600 x 1200 Max Digital
I have 1 LCD 17" and BenQ DV-2680 LCD TV.
I used the vga out to connect to 17" and as I don't have DVI cable, I used the DVI-VGA adapter provided and connect to the vga of the 26".
The max resolution I was able to attain is:
17": 1280x1024 (this is ok)
26": 1024x768 (NOT OK!)
I want to be able to have at least wide screen resolution (1600x1024) on my 26". Is this doable if I use DVI cable for the 26"?
I tried display properties and using the video card software to change the 26" resolution, but I can't get higher than 1024x768. I have updated the driver from eVGA.
Someone please help me. Thanks a lot in advance!
Hi everyone,
