Resolution changes
Planenutok
I have my resolutions set to 1280x1024 when i exit BF2 somehow my resolutions change to 1024x768. The bf2 setting are for 1280x1024. The change dosnt happen every time i exit only sometimes. But if i restart my comp without change it from 1024x768 the next time i boot it returns to the 1280x1024. Im stumped. Any suggestions welcome.
I have a similar problem with my HD LCDTV. It's native res is 1360x768 and it will stay that way fine for quite some time but then when it comes out of powersaving mode or
I reboot windows that res is screwed up (out of sync) and I have to drop down to 1280x720. I think it's a timing issue being just slightly out of wack and it probably can by fixed by using Powerstrip to fine tune the settings for that res. But Powerstrip costs $30.00.
It depends on the native resolution of your monitor/TV...It's very possible to run your monitor/tv out of its native res...but they have a need to 're-sync' every once in a while especially if they are undervolted somehow..And some of it depends on a capable graphics card and driver support...
