hi,
i'm pretty familiar with xp but up until recently i haven't had to deal with its network settings. (being previously spoiled by relatively pain-free static-ip network)
now that i'm on a dhcp connect, i'm having trouble with my router. or more specifically my windows network settings when (and only when) i'm connected to my router.
i have 2 comps on the router. my friend's works, mine doesnt. if i connect the cable modem directly to my computer it works. if i'm connected to the router it doesnt, and i also get this extra thing in my 'network connections':
under the heading 'internet gateway' - internet connection (residential gateway) (disabled)
previously i was having trouble with the cable modem and ran through the wizards a lot a times. i'm pretty sure at one point i selected the 'connects through residential gateway' option, which was wrong. but now i can't seem to undo that.
how to just start off clean?
reinstalling nic doesnt help. uninstalling the protocols/services in my lan properties doesn't help. it will only go away if i uncheck tcp/ip. but if i re-check it it comes back.
also if i load up ie and try to connect to a site it says 'detecting proxy settings'... then nothing.
would appreciate any help!
