Resetting RAM
Deschain
I was told by a friend to reset my RAM because i keep getting memory bluescreen errors, how would i go about doing this. I have OCZ DDR PC-3200 / 400MHz / Revision 3 / Performance Series Dual Channel sticks.
I'm 99% sure he meant reseat the RAM, which would basically involve removing your RAM, and then reinserting them. IIRC, OCZ has Lifetime Warranty, so you should be able to RMA them if the sticks turn out to be bad.
are you 100% that the errors are from the ram? what's your rig? try running memtest?
