Hey everyone, cisco noob trouble here.
I am trying to reset the configuration of a 2650xm router I got on ebay. I am following the password recovery instruction from CISCO but it is not working.
I am doing the break sequence to get into rommon then doing the confreg 0x2142 and reset commands.
However, when it restarts it is not bypassing the startup config like it should. What could cause? I am stumped.......
any help would be highly appreciated.
this is my output:
this is my output:
Password: ü
System Bootstrap, Version 12.2(8r) [cmong 8r], RELEASE SOFTWARE (fc1)
Copyright (c) 2003 by cisco Systems, Inc.
C2600 platform with 131072 Kbytes of main memory
monitor: command "boot" aborted due to user interrupt
rommon 1 > confreg 0x2142
You must reset or power cycle for new config to take effect
rommon 2 > reset
program load complete, entry point: 0x80008000, size: 0x9d57b0
Self decompressing the image : ######################################################### ######################################################################################## ############################################## [OK]
Smart Init is enabled
smart init is sizing iomem
ID MEMORY_REQ TYPE
00036E 0X000BA600 C2650XM Single Fast Ethernet
0X000F3BB0 public buffer pools
0X00211000 public particle pools
TOTAL: 0X003BF1B0
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 4Mb.
Using 3 percent iomem. [4Mb/128Mb]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco Internetwork Operating System Software
IOS (tm) C2600 Software (C2600-IS-M), Version 12.2(29), RELEASE SOFTWARE (fc3)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Wed 11-May-05 17:27 by kellmill
Image text-base: 0x8000808C, data-base: 0x8111B348
cisco 2650XM (MPC860P) processor (revision 0x200) with 126976K/4096K bytes of memory.
Processor board ID JAE080411WW (742437874)
M860 processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
32K bytes of non-volatile configuration memory.
49152K bytes of processor board System flash (Read/Write)
class VIDEO-** bandwidth percent 35
% Invalid input detected at '^' marker.
service-module t1 clock source internal
10.79.64.80 0.0.0.1
ost 144.226.
211.17
community mnsreadonly RO 66
snmp-server enable traps isdn call-information
Press RETURN to get started!
00:00:08: %LINK-3-UPDOWN: Interface FastEthernet0/0, changed state to up
00:00:08: %LINK-3-UPDOWN: Interface Serial0/0, changed state to down
*Mar 1 00:00:09: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, chang ed state to down
*Mar 1 00:00:09: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0, changed sta te to down
*Mar 1 00:00:12: %SYS-5-CONFIG_I: Configured from memory by console
*Mar 1 00:00:14: %SYS-5-RESTART: System restarted --
*Mar 1 00:00:14: %SNMP-5-COLDSTART: SNMP agent on host RTNCCARDR01 is undergoing a cold start
UNAUTHORIZED ACCESS PROHIBITED
Access to this system and associated network, computer
resource, or data is restricted to those authorized by
the company. This system and related networks, resources
or data may only be used for business purposes of the
company and its customers. Use by unauthorized individuals
or for an unauthorized purpose is a violation of Federal
and/or State law. Violators will be prosecuted.
Device is supported by MDS
RTNCCARDR01 line 0
User Access Verification
Password:
