Reset my admin password?
Kil4Thril
I did it- I forgot my login for my router. Now I cannot change any of my settings. It's a DLink Dl 624+ if that helps any. Can it be reset so a new password and such can be set up?
I couldn't find the book and Dlinks site was being stupid last night. I wasn't sure if a reset would do it. Now that I've seen it can, all will be well. Thanks for the reply.
just grave a pin or something and reset the router, theres a little hole on the back u stick teh pin into while its plugged in.
