leSLIe
- Oct 18, 2004
so I'm almost done testing my watercooling loop, and I've found that there are bubbles in the reservoir, is that normal?
The intake and the outtake barbs are at the bottom (red tubing), the top barb is the water feed (transparent tube), once the system is ok, i'll put a plug on it.
Also, should I fill the reservoir a little more? or its water is okey?
