Reservoir idea
I had an Idea of making the reservoir easy to fill by screwing it to some drive rails so that I can slide it out from the out side with ease so I can fill it up. Is this a good idea? If not than can some suggest better ones?
Sure, it sounds like a good idea. I can see why nobody has mass-marketed it--there would have to be a different model for every kind of drive rails out there. You might also think about just having some sort of fill port on the front of the res, so you wouldn't even have to slide it out. Or maybe a retractable something-or-other attached to the res.
If your case uses drive rails then they should attach to any 5 1/4" bay reservoir and there 'ya go.
Ok on this issue if your reservoir has A steal cap drill a whole in it . Than tap the hole you drilled with a 1/8 NPT pipe thread . purchase I stainless steal or copper thread pipe (1/8) and buy a fillport. run a tube to the filltube to the fillcap with installed pipe extension and problem solved.
