Do many of you reseat the chipset heatsinks of the motherboards?
How do you take off the heatsinks in a P5K-Deluxe? Is there any thermal compound already present? If so, what do you use to remove them?
I am think to reseat the heatsinks of the north and south bridges.
I read that some of these heat sinks are not properly mounted on the boards, eg: P5K-Deluxe, IP35-Pro, etc.
Is it easy to remove the heat sinks?
