I'd like a SFF PC for playing ESO, I'd like to keep cost to a minimum, however it should be able to play the game on max settings.
Thanks!
1) What will you be doing with this PC? Gaming? Photoshop? Web browsing? etc Elder Scrolls Online on maximum settings
2) What's your budget? Are tax and shipping included? £600 would be good, but can go higher
3) Which country do you live in? If the U.S, please tell us the state and city if possible. UK, however US links and prices are fine.
4) What exact parts do you need for that budget? CPU, RAM, case, etc. The word "Everything" is not a valid answer. Please list out all the parts you'll need. The case and all parts inside it, no need for external items (monitor, keyboard etc)
5) If reusing any parts, what parts will you be reusing? Please be especially specific about the power supply. List make and model. None
6) Will you be overclocking? No intention
7) What is the max resolution of your monitor? What size is it? Likely 22"ish HD
8) When do you plan on building/buying the PC? ASAP
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc. USB for peripherals
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? Is it 32bit or 64bit? I'll be purchasing a suitable OS, no need to be included in price though
Thanks!
