Hello all, I'm a first-time OC'er so, bear with me. I've read the FAQ's, and it is incredibly helpful. Unfortunately, I still have a few questions.
Here's my set-up:
Abit IP35 Pro mobo
C2Q Q6600 G0 stepping
ZALMAN CNPS9700 LED 110mm 2 Ball CPU Cooler
G.Skill DDR2 800 (F2-6400CL5D-4GBPQ) 8Gig
Vista 64 bit.
Project S-D case (see worklogs, it is a custom server case, should have decent airflow though)
So, how does one go about picking a number to OC to? If I lived in an ideal world, I would like to get up to, or as close to 3.6 GHz as I could.
Thus far, I've gotten it to boot up to 3.2GHz. Past that, It fails POST and restarts with stock settings. Currently, I'm leaving the voltages on Auto which are:
CPU core Voltage - 1.325v
DDR2 Voltage - 1.8v
CPU VTT Voltage - 1.2v
MCH voltage - 1.25v
ICH voltage - 1.05
ICHIO voltage - 1.5
I've been keeping my FSB / RAM in a 1:1 ratio.
I suppose my question is... If I wanted to push my CPU past 3.2, what would be the most likely place to start making adjustments. My coretemp readings are all at 25°c at idle at 3.2GHz, so it still looks like i have a decent window to work with there.
Any help?
Thanks!
Here's my set-up:
Abit IP35 Pro mobo
Vista 64 bit.
DDR2 Voltage - 1.8v
MCH voltage - 1.25v
ICH voltage - 1.05
ICHIO voltage - 1.5
Any help?
Thanks!
