Request for very simple script.
tarxsix
Hi, Sorry to bother you with this but I know very little about scripting.
I'm looking for a file that I could run that would select a already running WinAmp and press 'c' (the pause button).
I'm running Windows 10 Pro.
I've been trying to look up on how to do this but cant put it together in my head. Can anyone help?
Regards,
Tar.
JVene
A lot depends upon what language you're willing to use. "Script" is not well defined as to what tools you can use.
The basic notion is to obtain a handle to the desktop (the parent to all top level windows), loop through all that exist looking for the winamp name (probably part of the title), then sending a message to that app for the keystroke for the 'c'.
I think C# and VB can do this (I don't use either much), but it is certainly possible in C/C++ (not exactly for a novice, though).
tarxsix
Thank for the reply! I guess I would like to use something free? Would I need to install something? Honestly I thought I would just need to enter some text into notepad and save it as a bat file? Or do you mean the language that I would be using in notepad?
tarxsix
Sure.. powershell can do something like that.
https://stackoverflow.com/questions/17849522/how-to-perform-keystroke-inside-powershell
C# can, but you would need to install an IDE like visual studios to compile the app.
https://stackoverflow.com/questions/523405/how-to-send-text-to-notepad-in-c-win32
Thanks! Using PowerShell I tried creating the script and it opened WinAmp the first time but did not the 2nd as the window name changes with every song. So I tried the following:
$wshell = New-Object -ComObject wscript.shell;
$wshell.AppActivate('* Winamp *')
Sleep 1
$wshell.SendKeys('c')
But that did not work also. Any suggestions?
Also to run the ps1 file I have to right click and 'run with powershell'. Can I save it as a executable?
BinarySynapse
Try something like this ( haven't tested it ):
$proc = get-process winamp
$wshell.AppActivate($proc.MainWindowTitle)
Sleep 1
Reactions: xx0xx
tarxsix
Sleep 1
It's working! Thanks so much! And everyone else!
t4keheart
Just wanted to suggest, learn a little python. I'm a sys admin by trade but focus almost all of my efforts on developing python modules to automate everything. Python is super simple once you get a grip on it and has so many standard libraries for just about anything you want to do... had somebody not done this in powershell first, I was going to whip something up which would have taken probably 2 minutes!
