I'm thinking of building a new gaming system. My objective is that the system will be 2x faster than my current system (2.2ghz t-b amd with 9800pro with approx 10% overclock).
I'm not a big overclocker so the system will likely be overclocked 5% to 10% if at all. My hope was to stay around $1100. So the primary questions are will this system be 2x faster and do you have suggestions for part swap that would give the best bang for the buck (while retaining stability). Also - would I get nearly the same perf replacing my 9800pro with a 7900gt agp - and would that be better route to go?
Anyways system:
cpu:
amd x2 3800 ~$280
Disk
WD 250GB 16MB sataii ~$96
memory
G.Skill 2GB DDR 400 ~ $140
PSU
550 antec TruePower ~$98
Case
Cooler Master PAC-to1 or Kingwin 424 $45-$100
Video
7900GT ~$300
DVD-rom ~$25
MB
DFI nF4 Ultra-D ~$98
Sound
either built in or create labs 2zs from current system (built in on dfi might be as good)
kb/mouse already have
I think that's everythign for around $1120 (depending on day order and case)
Any comments/Suggestions ?
Anyways system:
cpu:
amd x2 3800 ~$280
Disk
memory
PSU
Case
Video
7900GT ~$300
DVD-rom ~$25
MB
Sound
