Request for advice on my new system build
max621
Hello everybody! I've been lurking these forums for a week or so, and decided I might as well register and see if anyone had last minute advice on my new build :)
My current (dead) pc is an 800mhz p3 with 384mb of ram, a 9700pro, 30gb maxtor + 200gb maxtor drives. The only two things I plan on migrating to the new system are the video card and hard drives.
I game quite a bit, and have been "gaming" with my crappy computer for much too long (little sidenote: it once actually resided in a cardboard box :eek: ) So my new system needs to be a pretty good gaming PC. I originally was planning to only spend about $500 on the system, but after deciding I wanted to OC it, I put more money into quality ram, cooling, PSU, etc. So without further banter, here is my current build list:
AMD Athlon 64 3000+, Socket 754, OEM - $135
DFI "LANPARTY UT nF3 250Gb" - $110
OCZ EL Platinum Revision 2 Dual Channel Kit 184-Pin 1GB(512MBx2) DDR PC-3200 - Retail - $265
Zalman CNPS7700-ALCU - $42
My case of choice is the thermaltake VA3000.
The only truely undecided part I have is the power supply. I will probably go with a 530W fortron or a 430-480W Antec.
The total right now is at $740 w/o shipping.
Obviously, a major bottleneck of the system will be the 9700pro. I will try to see how much I can overclock it on stock cooling. My plan is to wait out till summer when the new batch of video cards comes out, which hopefully will drive the prices of the 6600 and 6800 down.
Am I building a pc that will give me a good performance/price ratio? From what I've read, I should be able to OC this to around 2.4-2.5ghz. I don't expect to upgrade for a while, which is why I am sticking to socket 754 and saving some cash.
Both of my current HDs are 7200rpm ata133, but perhaps I should invest in a 36 or 74gb raptor?
Thanks for any input :D
If you don't plan on upgrading for a while possibly save some more cash and get a mobile xp chip paired with a nf7-s mobo. Other then that it looks great.
