Request: 6900XT Hashcat Benchmark
blade52x
I'm not interested in mining crypto, just unlocking a wallet I forgot the password to an am curious how fast a 6900XT may be in that regard. I've found a few 6800XT benchmarks, haven't seen anything on the 6900XT yet. Can someone who has a 6900XT run the hashcat benchmark on it? Specifically the following commands:
hashcat -b -m 1400
hashcat -b -m 1420
The benchmarks should only take a few seconds to run. Thanks!
hashcat -b -m 1400
Speed.#1.........: 10300.7 MH/s (64.90ms) @ Accel:256 Loops:1024 Thr:64 Vec:1
Started: Mon Jan 11 22:48:40 2021
Stopped: Mon Jan 11 22:49:22 2021
Benchmark relevant options:
* --optimized-kernel-enable
Hashmode: 1420 - sha256($salt.$pass)
Speed.#1.........: 9419.2 MH/s (70.99ms) @ Accel:512 Loops:512 Thr:64 Vec:1
Started: Mon Jan 11 22:49:38 2021
Stopped: Mon Jan 11 22:50:19 2021
BTW, do you know if this is any use on truecrypt hidden volumes? I have some discs and I think one of them has a wallet on it as well but I've been having a hell of a time determining which drive and none of the passwords I remember are working.
Thanks - that's actually about 5% faster than my 3090!
As far as your question - I'm not totally sure. But if you run "hashcat --help" you can see all the hash modes, and this shows up for TrueCrypt:
6211 | TrueCrypt RIPEMD160 + XTS 512 bit | Full-Disk Encryption (FDE)
6212 | TrueCrypt RIPEMD160 + XTS 1024 bit | Full-Disk Encryption (FDE)
6213 | TrueCrypt RIPEMD160 + XTS 1536 bit | Full-Disk Encryption (FDE)
6241 | TrueCrypt RIPEMD160 + XTS 512 bit + boot-mode | Full-Disk Encryption (FDE)
6242 | TrueCrypt RIPEMD160 + XTS 1024 bit + boot-mode | Full-Disk Encryption (FDE)
6243 | TrueCrypt RIPEMD160 + XTS 1536 bit + boot-mode | Full-Disk Encryption (FDE)
6221 | TrueCrypt SHA512 + XTS 512 bit | Full-Disk Encryption (FDE)
6222 | TrueCrypt SHA512 + XTS 1024 bit | Full-Disk Encryption (FDE)
6223 | TrueCrypt SHA512 + XTS 1536 bit | Full-Disk Encryption (FDE)
6231 | TrueCrypt Whirlpool + XTS 512 bit | Full-Disk Encryption (FDE)
6232 | TrueCrypt Whirlpool + XTS 1024 bit | Full-Disk Encryption (FDE)
6233 | TrueCrypt Whirlpool + XTS 1536 bit | Full-Disk Encryption (FDE)
I'm not sure if there are others in that list - but those are the ones that jumped out at me.
Hi
I would like to buy 6900XT and use it with Hashcat on Linux, but I'm not sure if 6900XT is currently supported.
I checked ROCm documentation, but I couldn't find an answer there.
I believe rocm drivers are integrated with standard AMD drivers now so maybe nothing special needs to be done. I can't remember if I ran my test on linux or windows but I could boot into linux and retest if you can share a guide on how to.
FWIW, I haven't had any issue getting ROCm cards working on a standard linux install so I believe that driver integration thing is working.
