interested
- Feb 3, 2006
Hello.
I am trying to help out a neighbour of ours, he is a senior citizen, who has a problem with his old PC.
Now my problem in trying to fix his PC is that it is much older then the usual pc's I have worked on over the last few years.
He is unfortunately still using Windows 98, and I dont even think its SE.
Had he asked me to fix it 8 years ago I would have had no problem doing so, as all the tips and tricks for that os would still be in my head.
However I have become spoiled with windows xp, and thus now find it dificullt to dig up old apps and tools I had which worked for 98.
Now normally I am pretty good at solving PC problems however its been quite a few years since I have had to work on any pc this old so I could use some advice on the following problem.
Ok here is his problem.
When his PC boots up , it shows the win98 login logo, then it gets to a blank desktop, and an error pops up stating that a problem occured in explorer.exe.
And thats it, nothing shows up on his desktop and nothing can be done other then ctrl alt del and restarting pc.
So it looks like explorer.exe is corrupted.( I am thinking bad sector on his HD, as I doubt very much he has a virus as he does not use internet )
Now normally what I would do is use a boot cd, or usb flash drive, and load up ERD commander or other similar boot recovery utility package or linux package, then run some apps to replace the system file in question ( explorer.exe.).
Now my problem is that his pc is so old that I cannot even boot from CD (let alone usb), as his bios only allows HD or Floppy boot.
Now I can F8 and boot into DOS with CD Rom support, however I cant find any old win98 recovery utility CD's that can be run from dos without the bios booting it first.
Thus can someone recommend any old similar recovery utilities that I can freely download which I can then run in dos, or any similar utilities which I can boot from floppy and works with windows98.
I am also going to try extracting the explorer.exe from a windows 98 cab file and try just manually replacing the file from within DOS. However I doubt that will work.
So any other ideas or old win98 tools that anyone can think of is well apreciated, as I just cant find my old win98 stuff and my memory on fixing issues with this old os is not that fresh.
Thanks in advance.
Thanks in advance.
