Reputable source for power supply connectors?
jack_r
I bought some cheap two wire panaflo fans with odd connectors on the end. I want to rewire these fans with 4 pin molex-type connectors that let me plug these fans into a standard ATX power supply via the same connections that normally plug into and IDE hard drive, or CDROM. I've seen these connectors on random websites, but I'd like to find a good reputable source (like Radio Shack, Digikey,... etc) to order from. Can anyone make a good recommendation?
I've bought a lot of fans and the cables from heatsinkfactory.com and I've been very happy with them. They have a lot of different connectors for the fans and am pretty sure they have what you need.
I know mouser has them, and jameco or digikey should stock them as well. There are part numbers for the connectors waaaaaaaaay down at the bottom of the original PSU FAQ, IIRC I got all these numbers from mouser:
Part Numbers for various connectors, Molex if not otherwise noted
First number is Connector, second is the other half
New 24-pin ATX Connector 44206-0007 and 39-01-2240
20-pin ATX Connector 39-01-2200 and 39-29-9202
4-pin P4 Connector 39-01-2040 and 39-29-9042
6-pin AUX 90331-0010 (no info on the mobo connector)
"Regular Molex" Drive Connectors AMP 1-480424-0, Molex 8981-04P and AMP 61314-1
SATA Connectors 675820000 and 675810000
Floppy Connector AMP 171822-4
Edit: it just hit me that what you're talking about is a panaflo tail... not just bare connectors :eek:
I don't see why one of those parts people wouldn't have those, but you might end up having to get them from a mod shop or something like that.
This info I've seen elsewhere..... but when you go to Digikey and search for these part numbers (especially in the case of the drive connectors that I want)... you get the parts that are already coming from the PSU... I want the opposite gender so I can cut the wires from the fans, put a new connector on, and plug the fans into the connectors that you mentioned... I can't find this information ANYWHERE.....
I have seen a couple of random webpages like this...
http://www.kdcomputers.com/eui/prime/profile/1143.htm
but I'd much rather find a well known source for these...
I highly recommend SVC. I buy from them quite a bit, they are cheap with great service.
P.S. With them, it's cheaper and faster to ship USPS Priority Mail, unless you live close to the West Coast.
