- Jan 27, 2003
I have an old D-tek spiral CPU block for a Socket A that I was wondering if I can do anything with.
I know to mount it would depend on the layout of the GPU PCB; but I was wondering if anyone has used old waterblocks and made an adapter to get it to fit on the GPU.
One thought was to custom make (milling machine) an 'adapter' to cover the GPU chip and any memory/VRM you'd want to which would provide a flush surface to mount the CPU waterblock to.
Basically I'm thinking you could use a copper waterblock and an aluminum 'cold plate', for lack of a better term. Here's a high res drawing (MS-Paint) of the concept:
Draft idea
One concern mig
ht be weight of it all hanging on the card/PCIExpress slot, maybe tying it to the case somehow would ease pressure. The spiral CPU block is pretty thick copper and weighs a decent amount. I was thinking this in conjuction with a Swiftech universal GPU cooler might make sense.
Other thoughts: does the memory even need to be actively cooled? It seems like the main heat source would be the GPU; perhaps universal cooler+ramsinks would be adequate.
A few notes:
Let me know what you think!
Kyle
Draft idea
One concern mig
A few notes:
- I know that this would be big and not allow for more than one GPU, this is for a solo GPU
- I know this takes more time and potentially money (depending on stock of aluminum/copper/access to machinery) than buying a block
- I've been dabbling with custom stuff for years and enjoy the process
Kyle
