I have a 120 GB HD that is getting full but is not damaged at all. I have a 500 GB WD SE16 SATA on its way via UPS. I not only want the extra space, but also want to reinstall Windows XP on a freshly formatted HD. Can I achieve this as follows?
I will probably later add the old 120 GB drive back in, but for now I mainly just want to know if I can do as outlined above. I want to make sure I end up with a freshly formatted HD and a fresh install of Windows. I am guessing one concern is that when I start up my computer with both drives in it (if the above steps makes sense), I want to ensure that it boots from the big new drive rather than the old drive which I suppose at that point would still have Windows on it.
Thanks for any help.
- remove current HD from my machine;
- physically install the new 500 GB HD in my machine;
- install Windows XP (Home) from CD onto the new HD;
- add my old HD as the second HD, connecting it to a separate SATA connection on my motherboard;
- copy data (not programs) from the old HD to the new one;
- remove the old HD;
- reinstall various programs on the new HD.
