Replacing Ti4600 with ATI 9200
phatjedi
I am taking out my Visiontek Ti4600 from my 2003 server box and replacing it with a 9200. I know I should always do a fresh install when changing hardware, but I am being lazy.
I know I need to un-install the drivers and clean up the registry of all Nvidia stuff. Can anyone recommend any programs that make sure all the nvidia drivers etc are gone? I have seen them on the forum before but search is not working.
Thank you.
:D
By the way, the reason it is coming out is noise. 9200 has heatsink on it without fan. Much quieter.
Try "Driver Cleaner", get it at major geeks. Its always worked for me.
And thanks for the explaination, because swapping those cards for performance reasons didn't make any sense to me.
He he. I figured I should explain before they sent some people after me. :D
Server box is for developement/work and not gaming. Although I am thinking of putting UT2004 on it so I can play with some folks from work.
Thanks for the heads up on driver cleaner.
PHEw!!!
i thought that same thing..lol
even if u install UT - just run it as a dedicted server :) and join form another system - best way to do it.
