Replacing the stacker drive bay fans?
Deadsexy
I'd like to replace the drive cage fan on my stacker case but am not 100% sure of the best way to do this. Anyone done it and have some tips?
I replaced mine with clear LED fans. Getting the fans off is the easy part - getting the new ones back on is the tricky part if the original connectors are too short. I had to use long screws from the inside to hold mine down.
