I have bought a new SSD and want to move the OS from my current laptops 7200rpm drive to the SSD of the same size. It is cut up into two partitions. The challenge is that the drive is running safeboot for encryption and it seems like I won't be able to remove it. This will likely be out of my control. Ghosting the drive will not be an option as according to everything I've read, the encryption is tied to the ID of the hard drive and windows will just blue screen if I do this.
I can, however, copy the files from one drive to another. I know that this generally does not work, but I was wondering if there's any way to swing it. I figured I might be able to copy the files and rebuild a MBR somehow without the tie ins to safeboot. Anyone have any ideas on how to deal with this? Thanks.
