Team Obi Juan
Your Local Postmaster
- Sep 28, 2005
I have had a standard HTIB + TV setup for 2 years now and am getting the itch to go full HTPC. But the first step is getting a receiver with some HDMI inputs. If I were to add an HTPC right now it would have to be HDMI to my TV's HDMI inputs, then out to my receiver/speakers for sound. This is currently how my xbox 360 is. Sounds good but I bet it's not optimal to have the TV mess with the signal. Current receiver has no HDMI inputs.
So I'm looking into receivers that I can HOPEFULLY use with my HTIB 5.1.
1) My current receiver powers my sub. What's the chances of finding a receiver that can do that?
2) My speakers do not have some proprietary plug at the end of the wires, just regular split speaker wire. Hopefully standalone receivers output to just regular positive and negative speaker wire?
3) I'm worried about ohms and all that stuff (back from my car audio days). Is that going to be a problem?
What receiver do you recommend for at least 2 or 3 HDMI inputs and 1 output? Can it power a sub? Budget between $200 and $300... lower the better.
