Not sure if all the boards are the same, but I removed the stock hsf and underneath is a black rubber shim around on the die. Can I safely remove this and install the new heatsink, or should I leave it and clean up the thermal paste around it? If I remove it to clean, should I put it back on before installing the new heatsink?
