Replacing NB fan
PinataUT
Got a bum fan on my ABIT and replacement arrived today.
I have to pop the board out, right?
Hello PinataUT,
yes, unfortunately you have to do that in order to reach the small clips that secure the HSF combo to the chipset.
Best regards.
my nb fan died and it could have been dead for a month or two before i noticed. i replaced the fan and all seems fine. could i have damaged the mobo?
Meh. Cooling that is overrated unless you give it a stupid voltage of 2v or something.
Well I haven't been OC this rig lately, and had pulled the watercooling...
I had a lockup and it wouldn't boot properly, but now I'm not convinced that it wasn't just a freeze followed by a bad connection to the monitor... I have the adapter on the standard monitor and it makes for a 3.5" lever into the vid card... so either the vidcard was not seated properly, the monitor wasn't connected to the card properly or both...
I must admit I'm tempted to fire it up and see how it does with some minor stress and the 'big' (120mm) fan to see what happens.
I can check temps on the NB with a sensor I guess (finger or if I feel like playing with it the DigiDoc that's boxed up somewhere in my office)...
Well I used tweezers to grab the plastic fan and pull it out a little from the hub and it is freely spinning. Temps are fine.
So much for my new computer I was going to buy... it'll keep until fall when i start playing more...
i had to do that on my Abit KT-7 board.i just went to radioshack and got a fan.
came home,unscrewed the fan from the NB,cut the connector on the dead fan and had my dad wire the connector onto the radio shack fan.
If you want to replace the HS, I'd advice you to look into some of the Zalman passively cooled products that you can put on the NB. They're guarenteed not to seize up when used :p
Thanks.
I can start and stop the NB fan at will. And I will to stop it more often since it started shrieking late this afternoon. Charming development.
So it has two modes: jammed and hollering.
I defragged my disc with it jammed and the fins on the heatsink remained cool to the touch given the other airflow...
I have the NB fan in a box, but because I managed to restart the old one, I have torn my office apart for cleaning / re-organizing. Grrr.
Needed doing, but not today...
Ok managed to remove the NB w/o removing anything from the mobo or the mobo from the case. Installed the NB fan w/o removing anything either. Was trickier getting it on... 2 hooks... I was convinced it was too long by a hair until i tried to reinstall the old one... and it did not appear to fit either. So I tried the new one and popped it in... yay.
