- Jun 12, 2001
I have a SilverStone Sugo 01 and the front USB Ports are broken and SS will not replace it since I bought the case from eBay
Anyway I am good at soldering and I want to replace the front ports myself but I don't know what the USB Block is called (Well USB Block but that turned up no searches to buy one) I cannot use the ports from a dead motherboard because the motherboards ports solder contacts are right angle and I need a block where it mounts directly on the board
Here are two pictures of what I need
I would probably need two ports as the first one broke so easily and I want a good quality port that will not break if I look at it wrong
Thanks
Thanks
