Replacing Abit IC7-G Chipset Fan
Lurk
Hello everyone, I'm here to ask about how people replaced their chipset fans on an Abit IC7-G Max II motherboard with a Zalman CNPS7000-Cu CPU fan. It looks pretty huge and I don't know which ones would fit.
Any ideas?
Thanks in advance!
I used a Swiftech MCX 159 on my MAX 3.....Works like a champ...You need the one on the right with the wire spring holders...
meh, the northbridge fan on my IC7 stop working 6 months ago, havent had any problems just leaving it as a passive heat sink. :cool:
I swear to god i am never buying another motherboard with active cooling on the chipset, the fans are always shit quality, even on premium boards from the likes of abit and asus. Nothing more annoying than the high pitched whirring on a dying northbridge fan. :rolleyes:
QFT :)
Mine has gone through stages of working/not working from about 7/03 until today... It even died so long I bought a replacement... it came in and then the original started working again, still has for 2 months straight.. Stupid fan...
This is the one on the shelf waiting to replace it:
http://www.vantecusa.com/p_ccb_a1c.html
Found several forums that suggested it as the replacement part...
