Replacing a speaker
athlon3400
I was wondering if there's a way to replace a speaker in my set of logitech 2200's? Logitech doesn't have anything on their site about it.
Email their customer support about the problem. They'll most likely send you a new set (dont ask them for a new one, of course). They'll probably ask you to send in the one speaker or nothing at all.
yeah i already did and they're sending me a new set, but the only thing wrong with the old set is one speaker is blown so I was wondering if I could replace it... and have 2 ;)
There aren't any skrews to open the speaker, I think it's glued shut. Has anyone else replaced a speaker on the Z-2300's?
athlon3400 said:
I found two speakers from a set of Z-560's. Would these work?
I think they are the same drivers. I have the Z-2200s and the Z-680s and they both use the same drivers.
