Replacing 2253BW to 24"
zakeus
I bought a Samsung 2253BW about a week ago and it is an awesome monitor.. but it just isn't big enough for me. I have a lot of 1080p documentaries and I hate reducing the size to fit the monitor, I want the true 1080p. I shipped it back today. I guess what I'm asking is what's the best 24" to replace the 22" I was used to. It seems that the most recommended 24" TN monitor on here is the BenQ 2400WD. Unless there's a non-TN panel that is below $450 then that is what I'm considering most. I loved the brightness on the Samsung, do you think the lowered brightness on the BenQ will make a big difference? I'm thinking if I keep the Benq at 100% it will be close to the Samsung at 90%? I know there's the 2493HM or the 245BW which have great brightness but more backlight bleeding, if I've been reading correctly. Plus the BenQ is a little cheaper. I need one that is compatible with the NeoFlex stand because I want to tilt it forward and raise it higher (which isn't the best angle for TN panels but I figure I can tilt it forward enough to make it look good).
Thanks for coupon code, that's an interesting design.. must be popular because they aren't available till 8/15
