Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I have an Asus Z170I Pro Gaming which has two antenna ports coming out the back panel. Can I just use any standard antenna in this slot? It came with what it claims is a dual-band antenna, but I dislike the design (it's corded, not direct mount).
Yeah, they're pretty standard. Just make sure whatever you get is also dual-band. If you're operating in a fixed location, a directional (vice omni-directional) antenna will help boost your signal quite a bit.
Corded antennas will also help, since you can get the antenna out from under the desk and away from sources or interference or blocked signals.
