replacement standoff for SLK-900U
irq21
I applied a little too much torque to one of the stock standoffs for my SLK-900U, and broke the threaded part off.
Does anyone know where a replacement can be purchased?
Contact thermalright and ask them about it. Make sure you tell them which revision of the heatsink you have. Version 1 and 2 use slightly different standoffs.
I might have used the wrong word in the above post.
I am talking about the brass (I think) standoff that screws into the x-plate then the standoffs with the springs screw into them.
Yeah I know what ya mean which revision of the heatsink do you have? I have the brass standoffs for a version 1 heatsink. The version 2 heatsink uses slightly different sized standoffs and screws. If you have version 1 heatsink PM me your info and I'll mail you the screws and standoffs.
I looked on thermalright's website and all I can find as a difference is the size of the screw with the spring on it. Mine is the smaller of the two. Is that the way to tell the difference between the two?
I'm not sure how to tell the difference all I know is that their is a difference. Sorry I can't be more help.
