Hey, I just wanted to ask if anyone know which panels are compatible replacement panels for the Lian Li PC-A05NB case. Also, if anyone has suggestions on where to get them, I would be most appreciative.
i think the lian li G50 side panels are compatible with the A05.. but performance-pcs sold out of those awhile back. those were the ones with the perforated holes for cpu & gpu
hampton technologies. get a reseller to order one for you if you are not a reseller yourself. buying from hampton saved me 50 bucks on my lian li case.
