I have a Cooler Master Stryker white case. The side panel that is on there does it's job but I would like to buy a side panel that has a full see through window instead of only part of the panel. Can I buy a good replacement side panel? Do they sell them with full windows that go from edge to edge?
It is a standard ATX case full tower so I am guessing anything with those specs would fit fine right? As long as the case grooves on the side panel match up to the frame of the case so it can actually be attached. Are there companies that sell side panels for cases?
Side panel color would have to match though. Any place that sells stuff like this?
Thanks
Thanks
