Replacement PSU for Dell Studio Slim 540S
frumpy_uk
Hiya
I hope someone can help. Per the title I'm looking to replace the PSU in my Dell studio slim 540S. Although I have replaced the noisy fan, the PSU is still noisy - it makes a high pitched fizzing noise at all times.
The stock unit is a AC Bel, model PC7067, 250W.
After much googling, I've found this : http://cgi.ebay.co.uk/TFX-PSU-ENP-22...213128002r3423
It's a SevenTeam ST-250TPD-02F. It has the same physical dimensions as the stock PSU. It's a 230W unit - lower than stock but according to the PSU calculator it's enough. Is there anything else I should be concerned about?
Any other suggestions for upgrades?
Stock AC Bel PSU spec :-
+5.0V ~ 19.5A
+3.3V ~ 10.5A
+12.0V ~ 16A
-12.0V ~ 0.3A
+5.0VS ~ 2.0A
thanks
Paul
What video card are you getting and what are the full specs of your system? You may not actually need anything more powerful than that Seasonic. And if you do need more power, you're probably SOL.
i'd toss that psu out the window if i saw it. IMO i never tried seasonic but maybe you have a better chance to test it out and maybe one of the users above have experience in having one.
update to 64kb. get a psu from like corsair any 80+ cert would work witht his system. good luck
I'm picking up the Sapphire Radeon HD 4650 :
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102829
My system spec are:
Intel Core 2 duo CPU E7200 @ 2.53GHz 2.53 GHz
RAM: 3 GB
32-bit Operating System
That's what it said in the properties of my system
The 300W Seasonic will be enough for your PC. That's pretty much as good as it'll get for you, so you may as well go for it.
Seasonic is one of the best PSU OEMs, and their products are almost universally good. And you didn't pay attention to the fact that the above poster needs a special form factor PSU for his PC, so not just any 80+ Corsair will do. I suggest that you inform yourself better and actually pay attention to the content of a post before you reply to one in the future.
Dimensions are pretty standard. However, connections are not, esp with Dell. You may need to make sure that the dell psu doesn't have proprietary connectors for the mobo they installed. this used to be a big problem with upgrading dell components. not sure if it still is.
