Replacement Mobo for ASUS A7v8X
lancew70
I need a replacement mobo for an ASUS A7V8X (rev 1).
Will the following mobo work as a replacement?
PC CHIPS M848A Socket A/SiS746 FX/FSB400/AGP/A&L/ATX Motherboard
http://www.ewiz.com/detail.php?name=MB-M848A&show=p#
($30 + $9 shp'n)
Looks like it should but thought it best to verify before I do anything rash. Or would you suggest other mobo?
the a7v8x has 1 leaking capacitor & 2 bulging. It's a friend's puter & I'm trying to get him out as cheap as possible for now... it's still a fast running little machine (has athlon 2000+ palamino & 1gb ddr)
I would replace it with an Asus A7N8X-E Deluxe or Asus A7N8X Deluxe v2. The nForce 2 chipset was best for Athlon XP. I had at least 5-6 different boards back then and the Asus's were my fav.
Check out the FS/T forum. I had bought a Asus A7N8X Deluxe v2 roughly two years ago for $25 shipped.
($30 + $9 shp'n)
The caps could be replaced for probally much less than buying a complete new board.
ZzBloopzZ... thanks...I'm checking with a poster now.
Spazilton... I'm no good with soldering...just how difficult is it? :)
