Replacement Mobo Advice
SolidSnakeUS
Okay, I currently have an ASRock P55 Extreme board and I want to replace with with the ASRock P55 Extreme4, mainly because of the SATA III and USB 3.0 ports on it because I want to keep my current i7-860 CPU (waiting to see how Bulldozer and whatnot turn out). My system should be in my signature and I've been trying my best to find comparisons in performance from my current one to the Extreme4. Is there pretty much no difference?
Also, I want a new board because for some reason, 2 SATA ports on my current board don't work and I'm using the other 4, so no room to expand anything, hell, I can't even hook up the eSATA port on the front of my case because of it.
But yeah, would the Extreme4 be a good choice? I don't overclock too much (if any), even though I do have a Corsair A70 on my CPU and good memory.
http://www.newegg.com/Product/Produ...rue&Keywords=(keywords)&Page=1#scrollFullInfo
They take the same cpus and memory.The expansion slots,storage devices are different.If you can split the monitor screen and look at them side-by-side you can get a good look at their differences.My opinon is they should preform the same.
The only cards I have on the system is a 5850 and an HT Omega Striker 7.1. Everything should fit fine.
Also, I like how they are vertical, but away from the first card. Honestly, it's easier for me in my situation for it to be vertical. Kinda iffy on it having the SATA III ports next to the 24 pin power connection though.
