I'm looking for a Replacement HSF for my Sapphire x800 XL. The little fan on it makes a little too much noise for my taste. I'm also hoping a better cooling solution will provide better overclocking results. What would you recommend?
There are very few aftermarket coolers that will fit in SFFs (other than the Aria). I'd recommend staying with stock, but check out the forums over at Sudhian in their SFF section. Great community, very knowledgeable.
